1 - 9 of 9 Posts
Hi guys, can anyone let me know what is the best oil to use in be Amg sport Cdi a200.
I want to make sure I use the best oils on the car?
Has anyone had one recommended?
Thanks guys
Greg
Make sure its an approved one for use in MB engines or you may invalidate your warranty.
My car (A220CDi) takes fully synthetic MB version 229.51. I would ring your local MB service dept to check though.
Here are some links that might help with oil choices - look foroils with "MB Approval" designation and that correspond to your engine. Check with your MB service representative and always consult your vehicle's handbook - there's no substitute for RTFM.
From the lists it looks like 229.51 is good for all engines - no info yet on the A180 CDImanual.
</font>
Common UK brands (229.51)</font>
<ul>[*]Castrol Edge: http://castroledge.com/oil-range/[*]Shell Helix Ultra: http://www.shellhelix.co.uk/shell-helix-ultra.html[*]BP Visco: http://www.bplubricants.com/en/products/visco-7000-5w-30[*]Mobil 1 ESP: http://www.mobil1.co.uk/synthetic-engine-oils/esp-formula-5w-30.aspx[/list]
Petrol Engines</font>
A180 BlueEFFICIENCY | A200 BlueEFFICIENCY | A250 BlueEFFICIENCY</font><ul>[*]229.3 - http://bevo.mercedes-benz.com/bevolisten/229.3_en.html[*]229.5 - http://bevo.mercedes-benz.com/bevolisten/229.5_en.html[*]229.51 - http://bevo.mercedes-benz.com/bevolisten/229.51_en.html[/list]
Diesel Engines with a diesel particle filter</font>A180 CDI BlueEFFICIENCY (auto) |A200 CDI BlueEFFICIENCY |A220 CDI BlueEFFICIENCY</font><ul dir="ltr">[*]228.51 - http://bevo.mercedes-benz.com/bevolisten/228.51_en.html[*]229.31 - http://bevo.mercedes-benz.com/bevolisten/229.31_en.html[*]229.51 - http://bevo.mercedes-benz.com/bevolisten/229.51_en.html[/list]
Diesel Engines without a diesel particle filter</font>A180 CDI BlueEFFICIENCY (auto) | </font>A200 CDI BlueEFFICIENCY | </font></font>A220 CDI Blue EFFICIENCY
</font>
<ul style="margin-right: 0px;" dir="ltr">[*]228.3 - http://bevo.mercedes-benz.com/bevolisten/228.3_en.html[*]228.5 - http://bevo.mercedes-benz.com/bevolisten/228.5_en.html[*]228.51 -http://bevo.mercedes-benz.com/bevolisten/228.51_en.html[*]229.3 -http://bevo.mercedes-benz.com/bevolisten/229.3_en.html[*]229.31 - http://bevo.mercedes-benz.com/bevolisten/229.31_en.html[*]229.5 -http://bevo.mercedes-benz.com/bevolisten/229.5_en.html[*]229.51 - http://bevo.mercedes-benz.com/bevolisten/229.51_en.html[/list]Manual update: "Use only SAE 0W-40 or SAE 5W-40 engine oils for AMG vehicles."If I've made any mistakes or you spot something out-of-date, please let me know and I'll happily edit the post ASAP. Hope this helps.
Edited by: IAMG
My A class came with a complimentary litre of Shell Ultra - diesel, not sure if this was courtesy of the dealer or MB - probably MB! So will use that. My previous C class last service had Shell oil rather than Mobil so perhaps MB have changed preferred supplier? Incidentally in first 2000 miles my A class does not appear to have used any oil, which is good I guess, but previous two C classes used a litre of oil in the first 1000 miles, then very little between services.
Didn't get oil with ours! Maybe it Mercedes way of saying it may use quite but oil at first! I suppose I better have look at level!
1 - 9 of 9 Posts
