Hi thereAnybody that can shed some light on my problem. I am busy replacing a starter motor on A190 from above. However to create more space I want to remove the rigid plastic watter coolant pipe(just in front of the oil filter housing). Only one torx screw is visible(clearly). Is there perhaps another screw behind thepipe or should one just force the pipe to release.
Keenly awaits guidance/help.
Regards
Cobus
Regards
Cobus
