1 - 10 of 10 Posts
Hi All
Does anyone know if there are any updates for the A200 Gearbox?
I’ve had my A200 for a few weeks now and find the gearbox does a odd thing when in second gear it’ll sit around 2000rpm and they’ll be a slight vibration (almost can describe it like if you’re in too low of a gear in a manual car you feel it dying off) - it’ll then change gear and they’ll be a judder.
What I’ve also noticed is that if I brake to stop for a roundabout for instance - the revs seem to go up slightly even though the cars stationary - not sure if this is a design feature to get the car off the mark?
I know the gearbox in the A200 is somewhat controversial between people after doing some digging) - but wondered if anyone’s had a similar problem and had an update or something similar? The car is a 68 Reg and just due it’s first service so not sure if there’s any updates since it was built new!
thanks all
My A200 AMG Line auto is around 2 months old (69 reg) & has none of the issues you describe. However you're not the first person here to complain of these issues.
Hi Sam, I started a thread in the Technical category about this. I have come to the conclusion that it's got to do with the cylinder deactivation. Vibration starts when I'm at about 1700-2000 rpm. Try turn off Start/Stop and you will hopefully notice that the vibration goes away. Cylinder deactivation is not enabled when in Sport mode or the Start/Stop is disabled.
I have a 2020 model and took delivery of it a month ago. I don't think there are any software updates for this, at least not yet.
Discussion Starter #4
Hi Tom thanks for the reply.
I took the car out for a few long drives today and switched stop start off each time and you’re 100% right it stops the vibration that I was describing.
Not sure if this was also a product of it but switching stop start off has eliminated the jerky gear changes which was directly after the vibration.
Feels like the car it should be now - I wonder if Mercedes plan to bring an update out for this? I’ll be switching stop start off every time I get in the car I think!
Thanks again.
Hi Sam I'm glad it worked for you too. Those vibrations are quite annoying so I'm glad there's a way to get rid of them.
I really hope Mercedes will address this in an update soon. It kind of defeats the purpose of having the start/stop function. It's in city traffic it is useful. I will definitely be switching it off every time I drive in the city.
Next time I'm out for a drive I will test if I notice any difference in the gear shifts as well, but when I think about it, you may be right!
Hi All
thanks all
Hello, there are gearbox updates that can be uploaded to your car.
Hello guys,
I have noticed that i hear small noises coming from gearbox when i leave my foot from the pedal or when changing gears with low revs especially from 2nd to 3rd. Some of these noises are barely heard, but they are annoying. I believe that i hear them more frequently now.
Has any of you heard any weird rattling noises coming from gearbox? You need to have radio off to hear them.
Hand mine a week or so and have noticed the vibration when going through start of the rev range in second sometimes. Supposedly had a gearbox software update, at my request, while it was recently in for repair for a unrelated matter. Still happening on occasions but it’s not terrible now, less vibration and for a much shorter rev range, can’t be sure anything was done though.
I do find second gear too long in both comfort and sport mode and also in comfort I find it changes down to second too soon, this is particularly annoying when travelling in 20-30mph zones with speed bumps. Always going from second to third and back.
Hopefully there is custom map available now or sometime in the near future as it’s not a bad little engine apart from some quirks.
Hi guys, I haven't noticed any unusual noises from my gearbox. About the long gears Deejay mentions, I have noticed it too, but for me it's the 3rd gear that is too long and it is in 3rd, just before shifting to 4th at around 2000 rpm I notice those vibrations. So now I either switch off Start/Stop or manually shift to 4th gear earlier than the auto would.
1 - 10 of 10 Posts
