1 - 4 of 4 Posts
Hi
Hope someone can help. Each time I try to recharge the battery (Public Pod-Point) I charging indicator flashes red as if there is a vehicle malfunction. I have tested with another cable and get the same issue.
Has anyone else had the same issue? Is there a simple way to reset charging? Or do I need to make a call to Mercedes services?
Is the charger you're using a socket or tethered charger? If it's a socket are you using the cable that came with your car?
I've found a similar issue when using the socket chargers at my work office, I've found sometimes the plug is a little sensitive on the chargers, which means the connection isn't always made first time.
In any case, if the car is under warranty (which it must be), it's worth a call to Mercedes Service or your dealer.
Thanks Diluculo. I am using socket chargers. I’ll speak to the service team on Monday. Sounds like it’s not a simple fix
1 - 4 of 4 Posts
