I've had my A250e Premium Plus since June 2020 (ordered Jan 2020, just before Covid!). However, I had a ' 7.4 kw' charger installed by BP Chargemaster and although all the advertising 'blurb' said it would fully charge in under 2 hours, the minimum time I've ever been able to charge in is around 3 hrs 45 min from 0 miles. The charging rate on the Mercedes Me app says 3.5 KW/hr and the same on BP Chargemaster (I don't use it anymore because it only tells me how much electricity I'm using and my Smart meter already tells me that!). Initially I thought it was the Mercedes supplied cable, which was only rated at 20Amps and as my basic physics goes, Power = Current x Voltage, therefore 20amps x 240volts = 4.8kw so to charge the 15.6 kw battery would take around 3 and a quarter hours with the supplied cable at maximum input. I had numerous conversations with Mercedes and they 'denied everything'. I thought that it must be down to charging cable so I purchased a guaranteed 32Amp charging cable, (32amps x 240volts = 7.68kw) so everything should be fine and having a 7.4kw wall box MB say it "can be charged via this with alternating current (AC) within 1 h 45 min from 10-100 percent SoC (State of Charge)". So now it charges at 3.6kw/hr with a charge time of 3hr 45 min as before.
BP deny that the box fitted is a 3.6kw box and, as far as I'm aware, the spec of the A250e 'on board charger, was not changed.
Short of getting an electrician in to check the BP box, or finding someone locally who has a 7.4 kw box I can try out, does anyone have any other suggestions why I cant get the shorter charging time? Most of the time through 'lockdown/Covid' the charging time was not a concern, but now everything is fully 'opened up', I find I'm needing to charge more often and a 3-4 hr charging time is becoming a problem.
Thanks
I had my BP Chargepoint installed in January - it was 'free' (well almost) with the car. Nothing but trouble. I have a schedule that matches the Octopus Go tariff to charge off peak at low cost. This worked for a while until one day charging started as soon as i plugged in to the car. This...
Thanks veeeight.
I'm pretty sure its not the cable and I don't think it could be the car as all the specs say the on-board charger is 7kw. Somebody mentioned in another forum that all the initial UK A250e's (of which mine has to be one because of Covid) were supplied with 20A cables, but as I mentioned, I've bought a 32A cable and that still only gives me 3.6kw.
However, I have had another look at my incoming electricity supply and find I only have an 80A fuse and I'm told that that can give a problem if you have high wattage electric showers, we have 9kw with a 40A fuse, and induction hobs, although they are both on a separate circuit and the electric shower is probably only used around 10-15 times a year and never when I'm charging.
I've also read on another (different) forum that Chargemaster supply both 16A and 32A boxes that look exactly the same and that they sometimes put a switch in the outside junction box to change it from 32A to 16A if the fuse domestic supply fuse is 'too low' (60A). That will now be my next investigation, as it is an easy one. If they have, my next point of contact will be with Western Power as I am sure I contacted them before I had the charger installed about 'upgrading' the fuse and they came and said I didn't need to.
I will let you know how it goes.
There are solutions for a limited incoming supply, although 80A shouldn’t be an issue.
There are products on the market that offer a halfway house solution (eg Garo Priority board/switch/relays) that will switch from one charger or shower, to another charger automatically so as not to overload the incomer, or a very modern Zappi 2 charger, that monitors via a CT the load and modulates the charge accodingly, and won't overload even if you have 2 electric showers and 2 EV chargers.
Hi veeeight,
Solution found!! There was a switch in the junction box and it was set to 16A. Talked to BP Pulse 'tech team' (???) and they said to change it to 32A. Guess what? Yes, my next charge took 1hr 42mins!
Rang them and asked why they didn't tell me that two years ago? The guy said he would send my complaint to the appropriate department! 1 week later there has been no contact!
There must be a body I can contact to complain about BP Chargenothing/BP No-Pulse? Is there some sort of Ombudsman?
Nobody from the initial installation told me and everybody I spoke to at BP told me it was a 32A 7kW box. It was, but had been stepped down and I wasn't told!
To say I'm livid, is understating things!
Related Threads
Mercedes A-Class Forum
194.7K posts
23.5K members
Since 2012
We're a forum community dedicated to the Mercedes-Benz A Class . Come join the discussion on performance upgrades, accessories, troubleshooting, maintenance and more!
