Varies but yesterday after a full charge it was showing 48 miles. In reality I got about 39 from it.What’s your full charge showing as in miles available?
ive only gone with the Bp ChargeMaster because of the free promotion Mercedes are doing.
It will take a few weeks until it learns your driving habits. I started at around 30 range and after two weeks am at 40. The outside temperature also effects the range. If I check my range first thing in the morning when its 6c the range is significantly less than if I check it again when it's around 11c.Wonder why mine only shows 31.7?
Thanks for that, ill keep an eye on it and see how it goes.It will take a few weeks until it learns your driving habits. I started at around 30 range and after two weeks am at 40. The outside temperature also effects the range. If I check my range first thing in the morning when its 6c the range is significantly less than if I check it again when it's around 11c.
Only way to do this is with either a charger with built in intelligence/timer function or with an external control relay/timer. I did the second option, as I quickly worked out like you that the departure time only refers to the climate control. As soon as you connect the charger to the car it starts charging, so the only way is to have some sort of timer to control the charger power.Just ha da Pod Point installed for my wife's A250e but there's no timing option. IF I set departure time in the MercedesMe app the car still charges immediately - seems departure time is only for pre-entry climate control.
I want to charge after midnight when my cheap tariff kicks-in - has anyone managed to do this?
I have been driving mine in Electric mode last couple of days instead of Comfort with the brake regen set at 1- and have seen a slight increase in my numbers from 31/32 upto 34/36 and this is doing the same commute everyday. I think during the winter months early 30's is where its at, Spring summer should see an increase in mileage per charge.Apparently when you go into the EQ menu on your car, there should be an option where you can set a schedule to charge the car between certain times (NOT the climate control).
I don't have it, bought the car brand new last Saturday. Do you guys?
Also, what range are you guys getting on average? I'm around 32miles on 100% at the moment... pretty low and frustrating.
I'll get back to you next August.You will not see 50-60 miles in the summer. That would put it at an efficiency better than Tesla & Kia (who make the most efficient EV's currently).
I don't see any such option on mine ?Apparently when you go into the EQ menu on your car, there should be an option where you can set a schedule to charge the car between certain times (NOT the climate control).
Neither do I. Is this when you're plugged in to the wall box, 3 pin socket or neither?I don't see any such option on mine ?
