41 - 46 of 46 Posts
Hi all. Has anybody have successfully programmed any charger to charge during low peak hours? I have read somewhere we need to set the time from the car itself too, in addition setting at the charger? Can anybody advise how to do that? Thanks. I am thinking to install pod-point home charger.
You only do it through the charger. There is no option through the car/MMe app to schedule charges.
A250e Sedan
I have a Wallbox Pulsar Plus which is a fantastic unit, looks great and is quite small so doesn't look too offensive on the side of the house. I set mine for 00:01 - 04:30 although the actual time to charge is around 1hr 45mins (7.2kw). There is no option to set schedule from the car, that's only on the fully electric models.
I'm been using ubitricity lampost charges for a while now and been getting a good 5.4kw + out of them. Since the weather has warmed up it starts off OK but then changes to 1.4kw. Has anyone else had this experience?
A250E Saloon Prem Plus
Just had a hypervolt 2.0 charger installed by a company called elecology. Both highly recommended. Only small issue was that I needed a wifi range extender so the charger could pick up the wifi signal. Once that was done setup with the app was completed in seconds, charge scheduling works perfectly. Charging at 7.5kw.
Installer commented that the unit was great quality, easy to install and customer service from hypervolt to get the final installation setup done was excellent.
41 - 46 of 46 Posts
