Maybe I missed it but doesn’t mention anything about rectifying the brake squeal? Is this something other 35 owners have experienced and would it be worth having MB look at this and most likely fob me off..
Also the centre caps seem to be getting corroded, is this something warranty would cover?
to add to the brake issue. I can also hear a slight clicking noise front the front wheels - sounds like somethings lightly catching, is it likely this is related to the brake or maybe a bearing issue?
also if it turns out a stone chip damaged the air con unit - are mb likely to charge me for diagnosing the issue ( cars under warranty )
I’ve tried the hard braking procedure a few times. It does reduce the noise but a few days later it’s back.. not sure if new discs / pads would rectify this..
Booked the car in at Mercedes who refused to
Give me a courtesy car as it wasn’t purchased through them, also mentioned if the faults aren’t covered by warranty there will be a £99 diagnosis charge.. would it be likely that they’ll try charge me if the ac failure is due to a stone chip.. typical crap customer service
21 - 25 of 25 Posts
