I realise that this wont appeal to all (and no doubt some comments will reflect that) but for those who say that you cannot fit a Towbar to an A35 you can. Had a Witter removable one fitted and coded using a mobile fitter who did an excellent job.
Towbar: Witter Detachable Swan Neck, 13 Pin Vehicle Specific Electrics
Witter Detachable Swan Towbar (vertical loading) | Witter Towbars
Fitting Company: Road Radio Ltd Crawley (cover the South East and will come to you to fit at home)
Road Radio
email: [email protected]
Tel: 01293 533941
First Off is your car homologated for towing?
Check the VIN plate on the driver’s side door pillar.
1st Line is the Gross Vehicle Weight of the car (2055Kg)
2nd line is the Gross Vehicle Weight when towing a trailer. (3955Kg) if this line is blank then your vehicle is NOT homologated for towing.
2nd line minus 1st line = Max Towing weight. E.g 3955 – 2055 = 1900Kg max towing weight
(Lines beginning 1- and 2- are front and rear axle weights
Do you need to cut the bumper?
Short answer yes but in my mind you cannot see it unless you are absolutely looking for it. (It disappears into the shadows) - See the picture below of the cut but also see the pictures of the finished car taken from behind at different angles – the cut is not visible. In the end you decide but I am happy with it.
Installation Photos
Crash Bar off
Tow Bar bolted on
What Bumper Cut?
And the reason I wanted a Tow Bar is to take this beast to other places
Road Radio
Tel: 01293 533941
Installation Photos
Crash Bar off
Tow Bar bolted on
What Bumper Cut?
The finished article.And the reason I wanted a Tow Bar is to take this beast to other places
