Hello, I have owned the A45 for 4 years in KOREA . of course SOUTH
first of all, My Cooler tuning is Alpha Side Inter Cooler, Wagner Large Capacity Radiator, AIR TEC Charge Cooler.
The current mileage is 80000KM
There is also a STAGE2 mapping.
But I have a strange problem these days.
If the mission temperature exceeds 100 ° C, it will not cool, but the Engine oil temperature and water temperature will decrease.
When I put the gear in the "P", the cooling starts, but it makes a lot of noise (the sound of the front fan spinning).
About 3 ~ 4 out of a45 owners in Korea are experiencing this problem, and some have been under warranty, so the symptoms have been alleviated by replacing the thermostat.
but 3 time changed during the 1 year LOL
And this mission temperature rises to 120 degrees. Even if I don't drive hard, just put it in "D" and the temperature rises.
What's more funny is that it doesn't light any warning lights
Therefore, the center says there is nothing to do.
As a result of checking with a diagnostic device, all functions such as oil pump, cooling water circulation pump, mission oil filter housing, thermostat, and cooling water are normal.
I need help from European A45 owners..
I wish you safety from covid-19
please note below mentioned PHOTO
