You’ve got away lightly with £184.Cars booked into Mercedes today. They updated software and still no change in lighting. They stripped the centre console and reported the wiring clips / loom had corroded.. they put this down to a liquid spill causing corrosion and making the lighting not work.. cost is £184, they need to back order that part.. I’m my 9 months of ownership I’ve never spilled any liquid to my knowledge.. does this sound like they’re pulling my leg? I’ve asked them to order the part for the wiring loom. They won’t cover it under warranty
Guess so. Now it’s working again I’m undecided if I should bother replacing it with a new loom?They look like theres been some sort of spillage
Looks all good underneathLooked underneath, any plugs undone?
Hi have you found a solution? because I have the exact same problem...so annoyingI noticed this morning that the ambiant lighting in the headrests on the passenger side front and rear are both out, drivers side both working as normal, just wondering if anyone had any advice on what this may be, I'm thinking possibly a fuse? As it's two out rather than one in which case I would think the buld. Any answers would be much appreciated.
Yes.Is this part of the slowly remove features as time goes on?
