1 - 4 of 4 Posts
2019 A250 AMG Line (W177)
Hello.
I have a little problem - the center console’s lid doesn’t close.
I’ve attached some pictures. It just doesn’t hook up. And as you can see, the release button is stuck down.
Any suggestions before I take the car to the dealership?
8342
8340
8341
There's something wrong with the spring as the button would normally return to its position when released. You can take the button module off and inspect. To do that you need to unclip it. There are two holes in the glove compartment and is to put a small screwdriver (ideally a 4mm Allen key, avoid a flat head) to unclip the module.
8353
1 - 4 of 4 Posts
