1 - 4 of 4 Posts
I may want to charge my battery soon, but I can't figure how to remove the battery cover. I can see the Red + sliding cover, but no way of getting to the other terminal. There is an arrow on the black cover, but I can't see how to remove it.
Yup as Ikon has posted, the official guidance for charging and jump starting is to use the main ground terminal at the left edge of the engine bay.
The battery cover does slide off fairly easily however, if you do need access. As indicated by the finger grips on the front edge, It slides forwards and lifts off, once the pressure of the retaining clips is overcome. However, my background is in engineering and I've a tendency to take these things for granted. Go easy and use judgement … you broke it you own it, not me :p
1 - 4 of 4 Posts
