1 - 2 of 2 Posts
hi I am helping a friend to fix his car, we changed the fuse body as the water had gone into the fuse box. this is replaced.
trying now to fix the eps abs lights, i can clear them with my autel obd but they come back up as soon as i move the car, i can see all the wheel sensors are working, i have cleared it a couple of times but no success, i will attach the pictures as i get two main obd faults
4580 Component 'A7/3 (Traction system hydraulic unit)' loose contact in voltage supply
and
supply voltage at control module esp and brake assist system bas control module n47-5
its a 2006 a150 w169 031. petrol model vin WDD1690312J326798
thanks in advance
Vincenzo
Personal computer Computer Audio equipment Output device Gadget
Hood Automotive exterior Vehicle Line Grille
Discussion Starter · #2 ·
Just in case you are looking and have the same issue. I took out the fuses that are connected with the abs. The 40 amp fuse being one of them. I cleaned them up and reset them. Put the car back together and no more warning lights.
I am not sure this is the fix but before i would only go a few meters and the lights would come on straight away.
Vincenzo
1 - 2 of 2 Posts
