1 - 7 of 7 Posts
When I read the codes through DTS I get this P13C204 error about the exhaust gas flap malfunctioning stored in the CPC_NG module. However I don't get any warning lamps or notice the car misbehaving.
First question is, do petrol engines have this flap installed? I know is on the diesels, but not sure on the M260 (I have an A250), as cannot seem to find such a part in the online catalogues.
Administrator
Is this the flap actuator on the very end of the exhaust silencer, the A35’s and A45’s has this actuator and flap.
Pics and drawings of A35/A45 flap and actuator here:
Yes is that one. Just checked underneath the car and is there. I ran the test procedure with Xentry and it says to change the module. I'll book it in, hopefully is covered by the warranty.
Discussion Starter · #4 ·
Update.... This is a strange one. I tested with Xentry, in the actuations tab you can actually tell it to open and close the flap. It responds to the commands, goes from 0 to 100 and I can hear it moving. Noticed that it defaults to 75% when not in test mode.
Anw let's see what they say. Is a 4 week wait to get to the service department in Colindale.
Update 2.... Months ago I posted this problem of mine. I took the car to the dealer, but without an exact problem to describe they just flashed the PTCU to the latest firmware. Error still registers on the ECU. So I decided to have a look myself. Turns out the flap is blocked and the spring connecting the flap to the actuator broke off. So the actuator is free spinning hence the error. I could not locate a replacement spring so decided to get the cheapest used actuator I could find on ebay to take the spring off it. Seems VW/Audi uses the identical part and they actually sell it for half the money MB wants (£150 vs £300).
I still haven't managed to unblock the flap, (need another wrench probably) but I will post again as I progress on this.
Wood Body jewelry Hardwood Wood stain Font
Camera lens Reflex camera Digital camera Gadget Camera accessory
Discussion Starter · #6 ·
Update 3... I haven't been able to unblock the flap. Is stuck shut. Sprayed copious amounts of WD40, but the flap will simply not move. No wonder the spring broke.
Does anyone know of a trick to unblock this?
Plumbing fixture Fluid Plumbing Water Gas
1 - 7 of 7 Posts
