1 - 6 of 6 Posts
My 2014 A200 has been experiencing right parking light, right indicator fault error message on dash. On checking, every thing seams to be working. Only indicator blink on dash is twice as fast. Actual indicators all of them blink normally.. I’ve been told this is whole a bumper off repair. Is this correct. TIA.
Do you have bulbs or LEDs in your head / tail lights?
If bulbs, that is symptom of a bad bulb of poor contact. If LEDs, say a pray, bumper off is the least of the problem.
It has LED drl and xenon main lights. I have found out elsewhere since posting, it’s the light control unit that’s failed. The car is only 41/2-5 years old. Not something that should fail so soon.
Behind the lights so I’ve been told. But not accessible without removing whole front bumper apparently.
I’ve also found out that when new LCU is fitted, garage has to link with Mercedes Tech Department via Internet to program the new unit because the car won’t recognise the new unit.
1 - 6 of 6 Posts
