1 - 1 of 1 Posts
Can someone help me this car is causing me to have a mental break down, about 4 months ago I had my Mercedes a a class 180d 2015 plate go into limp mode and the check engine light came on, I took it straight to the garage and It was the throttle pedal and it came up with the throttle body faults so I changed the accelerator pedal and the fault cleared and I drove it for a few days with no faults about 3 days after the car went into limp mode again, I took it to the technician to see about the wiring and it was all fine so I went ahead and changed the throttle body, same thing happened the car went into limp mode and just like before the Check engine light came on I’m struggling now cause I’ve done everything the fault codes come up with, would replacing the ECU be an idea? Cause it’s causing me so much stress got my first child on the way And I’m throwing money down the drain, Any advice would be grateful!
1 - 1 of 1 Posts
