1 - 3 of 3 Posts
I think I have seen all the modes that the car can display but I am wondering if you can have the speedometer rev counter and also display your mpg display on the same screen, is this mode available.
I am new to this technology and am a bit overwhelmed at the minute.
Thank you
Assuming 10 in screen, you can have the speedometer as large left dial, Rev counter as large right dial and a smaller mpg display in the middle (any of the different versions, eco etc)
Thank you
Hi yes, to do this you press the home/return button on the right side of the wheel until you get the options of Navigation, Media, Trip etc and you want to select Trip. When you have selected trip if you use touch sensors to select the middle area in between the rev counter and speedo and you should be able to change it to display the MPG.
1 - 3 of 3 Posts
