1 - 7 of 7 Posts
Hello. I had the same problem triggered by Start-Stop function. Root cause was a faulty auxiliary battery. It was measuring >12V, but under load was uncapable to hold it. I tested it droping to aprox. 8V.
Due to that, the car puts safety relevant funtions on hold. This is a possible root cause, but there are others.
Does your Start-Stop become available? Test both batterys, there´s a big probability that one of them is uncapable of holding voltage. It´s also relevant that the car was uncapable to diagnose the fault. There was no related error in memory!
Hi thanks for the reply. The eco stop start doesn’t work when this is on the light is off. Thank you, yesterday I turned it on and the lights had gone back off and steering was fine then today turned car back on and this all happened again.
Discussion Starter #7
1 - 7 of 7 Posts
