1 - 1 of 1 Posts
Premium Member
Recall SummaryMercedes A Class airbag may not deploy correctly.
Recall Issue
Mercedes is recalling some A Class cars because the front passenger airbag may not work properly.
The laser perforation of the instrument panel (i.e. the fracture point for the unfolding of an airbag) for the front passenger airbag may not have been performed correctly. In the event of a serious frontal collision the front passenger airbag may not deploy correctly.
</span>
Mercedes is recalling the affected A Class cars to check and, where necessary, replace the instrument panel.</span>
Mercedes A Class Cars Affected By This Recall
There are 111 Mercedes A Class cars affected by this recall. They were built between June 2012 and December 2012 and have VINs in the ranges:-
WDD1760002J000792 to EDD1760002J006767
WDD1760012J000756 to WDD1760002J021521
WDD1760032J000788 to WDD1760032J006783
WDD1760122J000763 to WDD1760122J016871
WDD1760422J000772 to WDD1760422J051173
WDD1760432J000773 to WDD1760432J006650
What Should Mercedes A Class Owners Do?
If you have, or believe you may have, one of the affected Mercedes A Class cars then please contact your local dealer.
Recall Launched
June 2013.
1 - 1 of 1 Posts
