I am a massive fan of the W176 A45 wheels and had a set so got them refurbed and hooked them up...
What do you think?
The only difference in these to the "Night Pack" W177 wheels is the offset, which is ET40 compared to these which are ET48. On the front's I have had to use 8mm spacers which then clear callipers etc, the turning circle seems fine and there is no scraping at all.
On the rears the hubs are slightly different and callipers are smaller therefore spacers weren't required however, I did buy another set and did try to fit them but the wheel hub was slightly different and the spacer seemed to sit flush rather than the wheel hub sitting slightly inside the centre bore of the wheel so I was uncomfortable using the spacers on the rear.
The car seems fine and although to the eye you can't really tell, consciously I know so want to get this aligned with the fronts.
Does anyone know why the rear hub is different and is there a risk with the wheel being flush to the hub? Is there different spacers which would be better?
P.S - don't judge how dirty the car is......
What do you think?
