1 - 5 of 5 Posts
A180 CDI, W176, VIN WDD1760072J222840, 724.003, K7A350
One Fine day I tried to startup the car and realized that the Instrument Cluster does not display the BOX on P,R,N,D. Tried cranking but no luck there.
Scanned the Car and received the following codes;
U119800Communication with the Intellegent Servo Module (ISM) has a MalfunctionCurrent & Stored
U010087Communication with the Control Unit "Combustion Engine" has a Malfunction. The Message is MissingCurrent & Stored
U010000No CAN Message was received from Control Unit "Engine"Current & Stored
U010187Communication with Control Unit "Transmission has a Malfunction. This message is MissingCurrent & Stored
U010387Communication with Electronic Sensor Level Module has a Malfunction. This message is MissingCurrent & Stored
C037100No can Message Was Received from the Control Unit "Transmission"Current & Stored
C054100No can Message Was Received from the Control Unit "Shift Module"Current & Stored
C06A100No can Message Was Received from the Control Unit "Engine"Current & Stored
C038500One or More Signal sent from Control Unit "Engine" via the Can bus is implausibleStored
C074300The Global Variant Coding Could Not be read Out of the Can BusCurrent & Stored
SCCMSteering Column Module (N80)1 Fault
ECMEngine Control Module (CDI)1 Fault
EPBElectrical Parking Break1 Fault
ESPElectronic Stability Program (N30/4)5 Faults
EPSElectronic Power Steering (N68)1 Fault
EZSElectronic Ignition Lock (N73)1 Fault
Finding it hard to figureout what the problem is .... can anyone help me out ... thanking you in advance
1 - 5 of 5 Posts
