1 - 1 of 1 Posts
Hi all. A45 Pre fl.
As subject says I have noticed this code ( P1CE700) when I checked the car with a diagnostic tool.
I recently had stage 2 done on my car and the dyno results came up short, read about 416BHP, the shop said should be around 435BHP, he mentioned that he noticed my turbo wastegate actuator was slightly loose and was most likely leaking air when the turbo is active possibly resulting in me loosing power.
Read another forum post that said he had the same code and turned out to be an air leak from one of his vacuum pipes. So just wondering if you guys think that the air escaping from my wastegate actuator could be the cause for this fault code ?.
Thanks all.
1 - 1 of 1 Posts
