1 - 11 of 11 Posts
Does anyone knows what is the maximum size of smartphone that we can put in the compartment (front).
iPhone XR will fit but not with a standard charging cable fitted. It will fit with a right angled cable though.
i dont care about charging, only to fit in the compartment, i have a Galaxy Note+ 6.8'' and i want to preorder the neo Galaxy S20ultra which is 6.9''
6.9 is the diagonal, not the length? and remember to add on any case to the length.
The compartment width is 7 inches at a tight squeeze.
Discussion Starter #9
hm didnt think it this way you are right. I think the S20 ultra is 166.9cm in height, whereas note10+ is 162.3cm
I've pre-ordered the S20U without even considering this.
Sod it I'm sure it'll fit, there's plenty of room with my S10 sat there, I only plonk it there to charge it a bit every now and then.
Discussion Starter #11
i am not sure because my note 10+ barely fits
1 - 11 of 11 Posts
