1 - 4 of 4 Posts
GOOD EVENING, MY CAR TEMPERATURE HAS COME TO THE RED, WHAT COULD BE THE PROBLEM ?
THANKS IN ADVANCE
Hello.
Start simple: check coolant level and if low try to locate leak. Can tempararelly fill it with tap whater. Check if radiator is not covered with leaks, mud, other.
If all this is ok, probably you have a sticky closed thermostat. If the car hets up normally but after that soon starts to overheat, that gives a strong evidence of sticky closed thermostat. This should be rare in a moders, new car, but can happen.
Discussion Starter #4
Hello.
Thank you very much,
ι changed the thermostat but the problem still exists
1 - 4 of 4 Posts
