1 - 4 of 4 Posts
On my Sport I don't like the look of the standard rear apron between the two exhausts -it's cut away on this model so that from the rear you can see the exhaust silencer box. I notice that on the AMG models this just goes straight across, and looks much neater. As this looks like a separate section of the rear bumper, does anyone know if the AMG park would fit and if so what is the part number?
Jinx said:
...I don't like the look of the standard rear apron between the two exhausts -it's cut away on this model so that from the rear you can see the exhaust silencer box.
+1 from my side, I understand that MB has this design in case a trailer hook is to be installed, but I never understand why the selected this not attractive design. They should at least cover this gap by use of a removable part...
<a href="http://www.aclassclub.co.uk/forum/amg-looks-almost-complete_topic2165.html" rel="nofollow">http://www.aclassclub.co.uk/forum/amg-looks-almost-complete_topic2165.html
</a>
You can change the diffuser if you want , I didn't like those gaps either .. and I always wanted the quad exhaust look anyway :p
http://www.kunzmann.de/shop/de/fahrzeugveredelung-mercedes-benz-a-klasse-w176.htm?page=3
Check out Kunzmann , I got mine from the dealer .. but Kunzmann is slightly cheaper. Installing the diffuser (apron) and exhaust tips is a PIECE OF CAKE!! I had someone who did it for free !!
There are just 2 things you need to becarefull off :
1 = I didn't get any bolts with my diffuser
2 = I got my exhaust pipes changed , I'm not sure if the original pipes fit. ( +AMG exhausts don't touch the exhaust tips , while 'your' exhaust tips are bolted on your exhaust pipes. )</span>
1 - 4 of 4 Posts
