1 - 8 of 8 Posts
Hi all,
Looking to replace pads all round. Fronts are no issue, but am sure the rears have a piston setback mode done through the trip computer.
Any ideas on how this is done?
Cheers dude, i presume its the same sequence for the FL aswel?
I did this a few weeks back on mine. 2018 FL car.
Trip computer screen must be on mileage when turning off car.
Ignition on only. Press Phone answer and OK together immediately after turning on.. Then the service menu appears. Select change rear pads and you will hear the rear calipers working for about 45 seconds then go quiet. Then turn off ignition.
change pads.
First time you put the ignition back on the calipers will wind and adjust up.
this doesn't work for my 2014 a200 amg sport. all videos referring to this relate to automatics so not sure whether manuals are different
As far as i know, this is the same for ALL mercedes cars with electric handbrakes. Even really old C classes with electric handbrake.
1 - 8 of 8 Posts
