</span>
</span>
</span>
</span>
Be careful with the sensors (light and rainsensor, and depending on the model also the camera). The plastic part can be bought at the dealer if you break them. It has two part numbers. I am not sure if they sell a plate for the alarm buttons seperately.
EDIT: I see you also have the alarm function. Be careful with that too. I don't know how the wiring harness goes, cause I don't have alarm function build in my car. But the pictures I posted should give you a general idea of the plate.
You can pop out the rear view mirror by using a screwdriver, but I don't recommend doing that. You can re-attach it by putting is back on the hexagon and rotate it counter clockwise. But you need special tools for that or a inbus (but the sensors are kind of in the way, so its hard job to do)
</span>
</span>
--------------------------------------------------------------------------------------------------------------------------</span>
</span>
</span>
Could you please help me too? Could you please show me the wiring harness of the dimming mirror? If you are done removing the plate.</span>
</span>
I want to know if the blue cable is either a seperate cable or attached together with the white cable. The white cable is for the lamps and the blue cable is for the dimming function. It's put away in the open space. and it's enveloped by a grey foam. Could you please make these photo's:</span>
</span>
-photo of the wiring harness connected to the rearview mirror</span>
-photo of the white connector, attached on the right side of the overhead lights (I see in the pictures you removed it with a creditcard). Could you show me which color wiring the white connector contains.
Edited by: Ace
