1 - 15 of 15 Posts
Hi all,
got the Rays TE37 19x8.5 ET45. is the rim and brake caliper clearance ok?
No contact or whatsoever when we rotated the rims
the mech said it was ok.
looking forward to hearing the thoughts of gurus and experts here....
Many thanks in advance
Car Land vehicle Wheel Tire Shoe
Wheel Tire Car Automotive lighting Automotive tire
That鈥檚 very close.
yeah that's what i thought...other than having the scary thought of a small stone getting between the caliper and the rims, i wonder if there will be other problems....like the brake caliper expanding from heat till it touches the rims....:eek:
Please do post a few pictures of the wheels once the tyres are fitted.
I have gone that aggressive before, but just to make sure, see if you can slide a credit card through the tightest point, which should be right below the AMG lettering. If it does slide through, does it just drop or it takes a slight push? Mine took a slight push, nothing that would scratch the paint or anything, but certainly wouldn't just drop. A credit card is about a millimeter thick and if you feel no friction whatsoever, you have more than that. If it does take a slight push, it's exactly a millimeter. I had that for about two years with my big brake setup, never had a problem, however there are two things you should note, one of which being the caliper expanding from heat as you said. While that wouldn't be an issue in normal driving or even some aggressive street driving, if you track the car you're gonna have considerably higher temps. Still, I seriously doubt that that alone would be enough to cause problems. The other thing is wheel flexing, which takes hard cornering and where do you normally do that? At the track. By hard cornering I mean, really hard. I'm not sure how your wheels are gonna flex, because it might be different depending on the wheel, but they will flex. Now those two together, caliper heat and wheel flexing, I just wouldn't track the car. But normal driving and some 3am blasts, never had a problem. Little stones getting in there is a possibility, certainly, but I think I did more than 10k miles with that setup, and never noticed a single scratch, so I'm sure it's not as easy as it sounds, like mad stone is gonna go straight for your caliper, unless I dunno, you drive on gravel roads often? You have a million stones dancing around your wheel at the same time, yeah, it could happen.
Nice wheels btw. Curious how copper and gray will mix, looking forward to more pics as @Forrester said.
Discussion Starter · #10 ·
thanks Theo! its really great to hear your experience! makes me feel so much more assured. :)
the thing is, I'm intending to use this set of rims for track. the stock rims will still be my daily. so i was wondering if i should get some hub centric spacers to let me sleep a little better before i head to the tracks.... if yes, am i right to also say that i should be getting longer wheel bolts as well? I'm thinking a 5mm should do the job. any gurus here can shed some light on this?
thanks in advance!
Sure. Yes I wouldn't track the car with that clearance, so definitely get spacers and yes you're gonna need longer bolts. I always had the impression that hub centric ones start at 10mm, with the exception of Racingline's Hub Adaptors as they call them, that are essentially spacers although not classified as such, and they mechanically mount onto the front face of the disc for a perfect fit, these are 5mm. Little different than actual spacers and much better to be honest, at least judging from how they mount, but I don't think you can use them without their brake kits. Anyways, why wouldn't you try a 10mm, are you lowered?
Discussion Starter · #13 ·
I'm not lowered. i was worried that with a +45 offset and 10mm spacers, it makes the overall offset a +35. and from what i'm told by some, to keep the offset to not less than +40.
that said, i went ahead to get some 10mm hub centric spacers with longer bolts. cos i agree with you that i shouldn't be tracking my car with that super aggressive clearance
I was planning on fitting 10mm hub centric spacers too, only for the looks, after a couple of members posted pics and the car looks stunning, even more than it already is. I was worried about fender rubbing but nobody has reported anything, on the stock suspension of course. The reason I changed my mind was that I just didn't want to affect the car's geometry in any way, but in your case, yeah I can see no option other than fitting those spacers. Btw you're gonna have pretty much the stock wheel clearance, I'm talking about the forged "Y" shape wheel option, which should be about 10mm. Please do report how the car handles though. Needless to say you should take it slow first, see how it handles and then push a little harder each time. (y)
Discussion Starter · #15 ·
noted Theo! great advice from you as always! will post some pics and update you all once i make it back from the track day. ;)
1 - 15 of 15 Posts
