1 - 7 of 7 Posts
hi guys! i have my a class about a month! i have noticed that sometimes engine doesnt start! so i have to turn the key back and try to start the engine again! why? do i make something wrong?
Lee551247 said:
Hope you haven't got the same problem as me as they still can't fix it after 2 months! Does anything happen at all when you turn the key?
Its only happened to me if I've already started turning the key before pressing the clutch. If I press the clutch then turn the key, it always works (touch wood).
Fortunately, my sales guy told me that if I were to stall, I have to completely turn the key back to the start (not just one turn to the electrics, but 2 clicks to the start position, then clutch then turn ignition again. If he hadn't told me that, I would expect there is a problem but going by what he said, it makes sense.
Yes, sometimes happens if you're too quick turning the key before the clutch is all the way down. Happened to me a couple of times before I got used to it.
1 - 7 of 7 Posts
