1 - 1 of 1 Posts
Hi Guys,
The car stopped starting literally between going to the shops, parking and coming back to the car and hey, right there in the parking lot, it gives a start error, if you reset by means of removing the terminal from the battery and replacing it it will swing/start but dies before it idles, then if u try right away again without resetting it doesnt even attempt to start, no click nothing.
We had two separate diagnostics done, one said driver authorization error, (car had that for a while but worked still) then the 2nd diagnostics, tested that the key was coded, it was so we were told to replace transponder ring, so we did, didnt fix the problem, we thinking possibly the actual immobilizer box, possible open circuit but we dont know.
Stumped here, so frustrated,please give any advise you may have
1 - 1 of 1 Posts
