I do have some WOT logs and partial throttle driving logs which include air intake temperature. But I am not sure whether the temperature was measured pre or post manifold as it was done via the OBD port and it is reporting whatever the ECU is seeing.
At 24-26 degree ambient, on partial throttle the temperature is between 38-45 degrees when driving around town between gear 1 to gear 4.
At 24-26 degree ambient, on wide open throttle the temperature is between 38-52 degrees. During the first 4 gears, temperature seems stable at 45 degrees, and on the 5th gear until redline the temperature rises very quickly and within one gear itself it could rise as much as 7 degrees.
Unfortunately I completely did not log anything much related to the transmission besides some torque related intervention by the TCU, and definitely nothing related to the clutch pressure. I am not even sure if there is a channel present to log for clutch pressure. Actually, I will try to identify it and log it the next time. It will be good to know for sure.
@changchewsoon
Thanks very much for your input, it is greatly appreciated and confirms our suspicions
There are only two inlet tract temperature sensors in our vehicles, standard.
1) A pre turbo sensor, immediately prior to compressor entry, in the plastic elbow.
2) In the inlet manifold, itself.
Your figures must be the inlet manifold figures.
So, your figures align with mine, if you add 10C to them to account for the difference in ambient temperature.
To operate a modern turbo vehicle. with inlet manifold temperatures 20C to 30C above ambient, is, from a performance perspective, literally unforgiveable.
Of course, being German, it is not an accident or mistake.
It is quite deliberate and for what are to them, perfectly good reasons.
IE Emissions compliance and Fuel consumption.
Now, if you start from an average UK ambient of 20C, it is still poor from a performance perspective; however, I guess, tolerable.
Where you and I live?
FAR from satisfactory.
At the moment I am waiting for Flow test results on the cylinder head.
Once I know the absolute potential of our engine, one way or another, I shall decide if I am going ahead with this vehicle.
IF I go ahead, then one of the first priorities will be to redesign the entire Intercooler system so that inlet manifold temperatures are only
10C at worst, higher than ambient.
Actually, if I do go ahead, I shall probably also incorporate a product made here in Australia, which for a short period of time, (say around 3 minutes at WOT) will keep the inlet manifold temperature approx. 20C,
BELOW ambient.
So, on a 40C ambient Australian summer day, the car will think it is operating in the UK in the middle of winter. ( -10C ambient?), with the standard intercooler system.
This will at least allow me to run Standing Miles without issue.
