1 - 10 of 10 Posts
Discussion Starter #1 (Edited)
I am a sound engineer, getting my AMG A45S, thought Burmester would be a good purchase to upgrade. But, I am not that happy with my Burmester sound system, feels like too much "polished" and not enough thump and crispness. I mostly listen to rock and heavy metal. Worked on EQ a lot, not satisfactory.
So, do you recommend changing the speakers, or anything more to do with the electronics?
Thanks for the info...
I was once into HiFi and the rule was then and still is now to always upgrade the source first. I have no clue how the unit in the MB would be upgraded as it all seems so integrated but a look at the MB models higher up the range would be a good starting point if I were considering it.
Reactions: Matt Ricks
I don't have the Burmester solution but I have massively improved the standard solution by adding a Audison prima box in the boot
It's a fair size. Did you do the wiring yourself.
1 - 10 of 10 Posts
