61 - 80 of 81 Posts
CLA 45S
Where's the best place to purchase this from? Seems to be £95 on the CPlay2air website, but £160 on Amazon. Any reason to go for the Amazon one?
I had an email exchange with CPlay2air because I wanted to ask about the availability or otherwise of an usb-c connection lead and this is their response below. Personally if I were buying one I can't see any problem getting it from their website although I haven't gone through the order process to find out the full shipping costs etc.
Thanks for your interest in our product!
Our team has tested it for Mercedes-Benz 2016-2020 models including Mercedes-Benz with the newest MBUX 2020 system with USB-C. USB-C ports are supported, sorry the adapter has a USB-A cable and you need an additional converter from USB-A to USB-C.
Product Link:
https://cplay2air.com/products/cplaystreamer-wireless-adapter-for-factory-carplay-android-auto-module-and-mirror-link-feature
Feel free to let us know should you need further assistance!
Charina
CARPLAY2air.com
My CPC200-U2W-PLUS from Amazon arrived today. Plugged into my car and it says “The connected device is not supported”.
Solid red light is on, but isn’t emitting any WiFi or Bluetooth signals.
Any suggestions before I send it back?
CLA 45S
If it's not outputting Bluetooth or WiFi then it may be defective.
Plug it into a USB wall charger and then try connecting to it. If that works, make sure it has the latest firmware.
Thanks for the reply. Finally figured out that the WiFi it was emitting was named VOLKSWAGEN. Used 12345678 as the password and connected, upgraded the firmware and now it’s working okay!
The car2airplay I have doesn’t work in my 2020 V177. It’s firmware is up to date as it works in my daughter’s Mazda 6. But when I plug it into the MBUX it says accessory not supported. I’ve used an Apple USB-C to USB-A adapter as well as a Baseus adapter. Unfortunately no luck.
Has anyone found a workaround?
Are you using the USB port by the ashtray and not in the armrest.
Has anyone used the MMB Multimedia box? (Aliexpress or resellers)
My cousin bought one for his E-class (2016) and it's working flawless, with options to watch Netflix/Youtube etc. (Yes I know safety etc)
But I'm wondering if anyone has used this for the W177. Can't try it out for myself cause I don't have the Carplay functionality..
A250 Mojave Silver
Do you have the latest MBUX version FUP3/NTG6?
I have the Carlinkit adapter and sat on it for many months "accessory not supported" (while it worked in other cars) until FUP3 / NTG6 came out. Then in a supported car did the adapter firmware update and tried it again in W177. Since then it works almost flawlessly.
I’ll need to check. I haven’t driven my V177 in a few days. How do I check which version I have?
A250 Mojave Silver
Go to Settings > System > System info (before last) and see what Software version says after apilevel. “ntg6/080” is the latest release. Previous release was “ntg6_fup2/063” I think.
Sorry for refreshing an old thread, but have anyone tried using any of these units without first paying for the f***ed up smartphone integration upgrade?
Hi!
My A200 was delivered last week and I was wondering the experience anyone had so far with CarPlay.
In my case, I wasn't able to to use new "wireless CarPlay" feature the new A-Class MBUX was supposed to deliver. Anyone was able to activate it like that?
Wired with the USB adaptor works as expected, of course.
On the same side, I got the 10.25" touch screen for media. Whenever CarPlay is active, it shows like a pretty small square with bars on each side (some info about temperature and time), instead of using the 10.25" in full screen for CarPlay.
With my experience with a 2019 E-Class, there is an option to remove some info from that panel, thus making CarPlay used the whole 12" screen. Couldn't find a similar option with MBUX on A-Class.
Any thoughts?
Thanks!
I've just been doing research on this. There is a lot of information on this here: CarPlay adapter to convert to wireless CarPlay?
I mainly use Apple but will also use google, I have been paying a lot of attention to the various discussions that periodically pop here about wireless adapters. Finally, I got a dongle from Smart Box. It's a new version that is similar in hardware but has a USB-C connector on the box and you plug a (Removable) USB-C cable into it. Probably the later USB-C version just in case it boots quicker. It supports TV projection and online Youtube watching. Works perfectly on my 2017 A200.
Highly recommended!
Does anyone have any experience of the wireless CarPlay adapter? It looks a little bit like carlinkit , but I am not sure.
Greetings,
Just a shot in the dark here, but does anyone use this dongle - carlinkitcarplay? (or a device similar to it). Where it turns the factory installed Apple CarPlay in your Mercedes-Benz (2016-2019) into a wireless solution.
And if so, if you could please assist with the following two questions:
Does it reliably connect every single time? Or do you find yourself having to frequently adjust the settings.
Does your phone automatically & quickly connect once you start your vehicle?
Thanks so much for the insight, I really want to place an order on a 2020 A-Class, but not having wireless CarPlay is a dealbreaker.
61 - 80 of 81 Posts
