It would be useful to get a handle on what's going on with the A35 engine and how many are effected and how long MB are taking to get the cars fixed
Approved used Mercedes so from dealer 2 years as it’s Amg. There was no quibble about it. I’d drive it. But if it goes wrong, get a private recovery and report it when your warranty startsDid you have extended warranty.. I've bought the extended warranty but it doesnt start till June 13th .. almost scared to drive it till then..
Glad to hear you have been given a resolution. hopefully it doesn't take long to sort.
I have it with stage 1 240hp~~ since 18.6k milesRally does seem to be pot luck with this. I’ve had some very heavy modded cars and drive them with respect. Especially forced induction. I was very surprised its failed on 3….usually just the one From what I’ve read.
240? What model have you got? This is an AMG 35I have it with stage 1 240hp~~ since 18.6k miles
220 same engine block m260240? What model have you got? This is an AMG 35which is 300+ stock
What Merc don’t tell you is you are buying a Renault powered Mercedes 😂 I believe the 260 is a Renault block? If I had known, I’d have got something else220 same engine block m260
M260 its full MB the problem its the block, same issue in A220/A250/A35 same engine/blockWhat Merc don’t tell you is you are buying a Renault powered Mercedes 😂 I believe the 260 is a Renault block? If I had known, I’d have got something else
Wasn’t it the Renault/mitsi/Merc collaboration engine? Always destined for disaster! Bit like the Citroen nemo. / pug bipper / fiat fiorino micro van.M260 its full MB the problem its the block, same issue in A220/A250/A35 same engine/block
The renault its a180/a200 1.3 and a250e 1.3/electric
I’d agree with that. 👍There have been reports of the A220 having the same issue as the A35. I imagine the A220 block is less stressed in its application, so the numbers are less.
MB now use an "MB" 1.3 engine but Nissan's use of the engine still continues and I posted about some of the Qashqai's problems.Wasn’t it the Renault/mitsi/Merc collaboration engine? Always destined for disaster! Bit like the Citroen nemo. / pug bipper / fiat fiorino micro van.
3 manufacturers all donating bits. Parts nightmare!
That colaboración is 180-200 engineWasn’t it the Renault/mitsi/Merc collaboration engine? Always destined for disaster! Bit like the Citroen nemo. / pug bipper / fiat fiorino micro van.
In spain there its more 220/250 problems than a35 its same block but its not the same some parts of the a35 are forged and better coolant pieces etc...There have been reports of the A220 having the same issue as the A35. I imagine the A220 block is less stressed in its application, so the numbers are less.
I stand corrected 😂 tbh it was my car nut son that said it was the Renault block in mine. I shall suitably chastise bwhahahaha!That colaboración is 180-200 engine
My parents lived in the canaries for over a decade. The toll taken on cars there is horrific! Heat/sun/dust ruin just about every part of a new car. I guess climate is a factor 👍In spain there its more 220/250 problems than a35 its same block but its not the same some parts of the a35 are forged and better coolant pieces etc...
The 180/200 is Renault in 1.3L. But the sales guy, and while I don't often rely on them, but he did seem a cut better than ones I have previously come across, said it is MB. I researched it and while it is a Renault block, I have not come across the same issues and think it is up to a good MB standard. That is the issues the Nissans have suffered seem not to happen. I stand to be corrected if others know different.I stand corrected 😂 tbh it was my car nut son that said it was the Renault block in mine. I shall suitably chastise bwhahahaha!
Yes they completed it Wednesday but didn’t replace the tensioner to cure the cold start chirping - parts in order but I’m in a ticking clock!@Gnome Any update on the eta for your new head.
That's until August right? Many worse things to be doing.Going to be a mental summer gigging round all the Europe f1 tracks!
Yes mate basically all tracks Barcelona thru monza includedThat's until August right? Many worse things to be doing.
