is it possible to insert a photo for each profile?
Can't remember if I had to do anything else, maybe there's something more you have to do within your Personal Profile Settings in the car? I'll see if I an find anything else I did, next time I'm in mineRight, it says I am the first of seven and I have got auto sync on, still not showing, any ideas anyone?
Ahh, hang fire, you say it's telling you that you are the FIRST of 7?.. Then you haven't actually added yourself yet. I know it sounds irrational and a bit bizarre, but I've just checked mine in the Portal, and although I am the only User, it says I have used 2 slots. This is because even though you have a MercedesMe Profile, you still need to click the ADD button and add yourself again (I don't know why this is, but it works). So basically use up a second "slot", add yourself, upload a Profile photo, and after that you should see that photo in your car when you next get in it and it updates to the vehicle.Right, it says I am the first of seven and I have got auto sync on, still not showing, any ideas anyone?
No, I don't think that's the case, I don't remember doing anything IN the car before creating my "second" profile on the portal (I know, its not really the second, its kind of the first, but that's the odd thing about the User Settings on the Portal, I can't explain it either)... although maybe after that the car asked me to do that? Not sure, sorry.Wierd, I suppose you might have to make a second profile in the car first?
Conclusion: Mercedes just loves to keep us baffled and confused. HahahaMore wierd after the discussion yesterday , I haven’t touched anything but my photo is now up and so is all the profile stuff with it. I didn’t need to create a second profile it worked on number one.
There is no save, it is automatic that any adjustments made while in your profile should be autosaved.
I find I can beat the boot up time of the car, if I was the last driver I can jump in and go of course.
But I think the car is not supposed to move the seat when you are moving, so if you start the car, change profile, and move before the dash has finished booting, it may not complete.
The other bug I found was swapping seats with my wife, I pulled up at the side of the road, switched off, swapped seats but it would not change to her profile, possible because we had not shut the doors to power down the system.
Both as far as I can see! I think they are independent of one another.Are the seat memories saved within your profile or are they independent?
So 2 x different positions for each profile?
I’ve not got mine yet but I can’t actually get behind the wheel after my lass has been driving to shut the door and select the profile, so can I press the seat button on the door before I get in even the a profile hasn’t been selected? would be so much easier saving a profile to a key like BMW.
