is it possible to insert a photo for each profile?
It is using the correct profile, it's just randomIf you dont select a profile, it will use the Guest profile. The MBUX start-up is slow, so the profiles dont come up quick enough.
If you do select your profile, does the radio station default to the last station listened to? or you have to select the station each time the car starts?
That might be the case but this is different, its probable that it is to do with software like many of the issues we findI think I read in the manual that it won’t make seat changes if the car is started/running - maybe a safety feature of some sort?
Did u login into the portal as your wife (co user) and then try?The co-user is registered and the name appears in the car, but there is no settings icon in the portal to enable the profile preferences as there is for the main driver.
Yes. She has to have a separate mercedes me id.As a co-user she doesn't have a separate login, surely?
again, did you login using your wife's mercedes me id in the portal? you should be able to change her settings under 'personalisation'I now have her photo in the car after syncing but on the portal I can’t see a way of enabling any preferences like I could for myself.
I can't figure out how to sync. Where exactly do you find that.I now have her photo in the car after syncing.....
