81 - 100 of 203 Posts
I have a 10 m0nth old A220d AMG line,this had a rattle at first it seemed to come from the rear of the car .passengers thought near side .Took it back to Mercedes dealer ,who replaced lower front suspension arm two shock absorbers and updated top suspension mounts ,after that all rattles disappeared even some i thought were were coming from the dash.all of this on warranty
I have a 2018 A200 - W177. It's white and I like it.
I bought it 6 months ago when the icebox I now call home was full of snow and I had to use winter tyres. Now the snow has left and I'm using my summer tyres so the ride is much quieter and the passenger side has a terrible rattle which is destroying my soul.
I've done plenty of reading online and can't really find anything that points to it. Does anyone have some smart ideas on where it may be coming from and or how i can fix it. I work in an environment where I have access to a whole world of tools and I have reasonable skills with these kind of things but I just can't find where it's coming from.
I work & live between two cities (A bad idea I know) and I drive around 500-750kms per week so i spend a lot of time in it. It's not a problem at city speeds (50-60kph) but on the highway (100-120kph) its very annoying and turning up the music only helps slightly.
I'm willing to send the wizard who can help me end this nightmare enough money to cover the cost of a large glass of whatever poison you drink.
Save My Soul
JJ
Save My Soul
I have a A180SE 2019. I had a similar problem a few months ago that was driving me insane!
My creaking was from the rear passenger door. Try to get someone to sit in the back of the car and press and prod the trim by the windows. See if that helps. Also the rear parcel shelf is worth checking!
Just to add to this I would also check that your seat backs are properly locked in place without seatbelts blocking them being locked.
Thanks for the suggestions, I checked the rear seats and had a look around the rear door cards tonight but nothing seemed out of place.
I'm thinking the problem is somewhere around the area of the glovebox, It almost around like something inside the glovebox is rattling but I have emptied everything from it.
I tired to record the sound but it didn't turn out so well
The lid (inside the upper glovebox) that holds the owners manual, can "buzz" and rattle. Sounds a bit like a spring.
It's the "hidden" compartment inside the glovebox.
If you drive along with the glovebox open, and hold the inside upper lid still, it will stop, if that is where your sound is coming from.
I have looked at this in the past also and removed the manual from there but i'll take a look at it again because I think it's a strong candidate.
JJ
Hi! I had a rattling noise like a tiny little screw was loose somewhere around the passenger side airvent. When I asked a friend riding with me to check where it came from he said it came from my side. Anyhow, I opened the sunglass compartment at the rearview mirror, and the rattle stopped. I went to the dealer and they changed the whole ceiling unit. Noise gone!
Without the manual, mine buzzes more. I have to jam the manual in such a way that it presses certain areas of the lid/cover, and that stops the buzz.
I went with a friend today and he played around with the manual compartment in the glove box and it didn't change anything. He also said he thought the sound was coming from the middle of the dash area.
I have read something about the displays making sounds and needing some tape over some screws. Anyone know anything about this?
JJ
I have someone tell me something similar today, I think its from the passenger side and he said it was more central to the dash area, I will check around the mirror tomorrow.
I have a three hour drive home tomorrow with the annoying rattle 😩
JJ
JJ
Yes, there is a service bulletin issued to the dealers about removing the display, and inserting foam tape in a certain area.
But it only covers cars within a specific VIN range.
Hello. So i fixed all of mine rattles in the A class. First one came from
  • sunglass compartment above head ( there is spring inside which i removed - place the credit card in the back of the upper panel and it will fall down and remove spring ) google for more info
  • A pillars on both sides, i removed them and placed felt tape on all touching plastic connections
  • B pillar removed and placed felt tape
  • removed all panels from doors and placed felt tape all around the doors. took around 10 meters total 1.5cm thick felt tape.
  • Side panels of dashboard (driver and passanger side), felt taped again all touching points.
All of this is easy done, i bought on ebay workshop WIS and read alot.
This is the highest qauality felt tape i have found on the internet. Same one that mercedes dealer gave me and wanted me to pay 10 euro for 1 meter. Assholes
