What model rear diff oil needs to be replaced ?75W-85?75W-90or75W-140?
Of course, it's safer to go to the dealerCan be replaced,Because the things given are the same
If it wasn't for this forum, come May I would've taken it in and they would've said that almost everything I needed for the service was out of stock. And I'd be on my way home, very pissed. I'm pissed now, but at least I feel a little better knowing I have saved myself a little time, having placed my order in advance. But I wonder if joining a forum is a prerequisite for owning this vehicle.And if it wasn’t for this forum I wouldn’t have realised.
Much appreciated!According to my list:
Rear Diff:
Gear set - M-B 235.63 - not in service schedule, "lubed for life" 😂
Coupling - M-B 235.64 - A0009894406
No diff filter. Left and Right coupling separate fills.
Gearbox (I'm not 100% sure of the parts below, so check with your dealer):
Filter - A2463772300
O Ring - A0229978045
ATF - M-B 236.22 - A0009896104
@veeeight will address the Tier One supplier question.All,
Owner of a 2021 CLA 45 with the TWIN torque vectoring rear axle and have been attempting to locate reliable, definitive service information for quite a while now without much success. I am an active member of another popular MB forum but, apparently, there are very few c118 CLA 45 enthusiasts in the U.S. so I’ll try posting here. Anyway, based on my research, the 45 uses a rear axle unit manufactured by Magna – the same supplier of nearly identical torque vectoring rear axles used on the new Audi RS3 and VW MK8 Golf R. While MB does not list a part number to coincide with the 235.63 specification (center section gear oil), I have access to VW’s erWin maintenance system and they spec the following for the Magna unit in the Golf R:
Center Section Gear Oil: G-060-190-A2
Clutch Oil: G-055-515-A2 (I have confirmed this is a cross to Shell TF 0870 & MB 000-989-440-611)
Finally, being an avid DIY’er for maintenance, I have a dedicated laptop running a very current version of Xentry (late 2022) and WIS lists no procedure for changing the rear axle oil – not for the center section gear set or clutch packs – but does state that it should be changed at 30,000 miles or 3 years (aware that this may have changed to 37,000 miles or 4 years).
So to summarize, I’m coming up on this service, am interested in DIY’ing it, but still need the following information if anyone can assist:
Oh, one final note, the Golf R procedure in erWin suggests the clutch oil condition can be checked via diagnostic software and that the oil condition needs to be “reset” upon changing. It further states that driving style (read: driving aggressively) can drastically reduce the required service interval of the clutch packs. I have not verified if our rear axle is also digitally monitored.
- The WIS procedure for changing the rear axle clutch and gear oil (potentially document #AP35.00-P-3501F if anyone feels like searching by document number in WIS)
- MB part number for the drain/fill plugs. VW seems to want all drain and fill plugs replaced when performing this service on the Golf R (all 6 of them – VW’s part number for the drain/fill plugs is N90281802; I’d be willing to bet these are the same for the 45’s rear as well but my version of EPC doesn’t cover the c118)
- Confirmation that the Golf R’s center section gear oil (G-060-190-A2) will suffice for MB’s 235.63 (75W80) gear oil spec.
Number 1 reason for changing the A45s rear coupling sections (Left & Right) more often, as opposed to less often:
The A45s configuration and calibration is to give “more” rear drive feeling, say compared to a Golf 8R. So the rear coupling clutches (Left & Right) are experiencing more slip engagement more of the time. Slipping clutches in oil leads the oil to deteriorate quicker than non slipping clutches
The M-B spec oil for the rear couplings (Left & Right) is M-B 235.64 - A0009894406. 0.4 litres per side. Shell Equivalent TF0870 B. The “B” is different to the G8R non-B oil suffix? Does this make a huge difference? Don’t know.🤷♂️ But I would stick to the M-B part number above.
Yes Magna is supplier for G8R and RS3 rears.Was our friend in the ME correct regarding Magna being the Tier One on the VAG differential assemblies?
@veeeight, are you able to identify which of the Magna Europe plants builds the rear axle assembly in the VAG product?Yes Magna is supplier for G8R and RS3 rears.
With respect to A45s it’s more murky! - I was always told that that AMG did the development with Steyr - but of course Magna bought Steyr. But more likely AMG worked with Steyr OE in-house engineers, so the calibration IP of Audi and AMG would not be available to each other.
But neither AMG nor Magna have ever declared in public that Magna supply the A45s rear unit, or that it is the same unit as in G8R/RS3, only a couple of motoring journalists have put 2&2 together and maybe come up with 5.
So could they share a casing? Possibly. Internals? Possibly very similar. Or they could be different units!
M-B has no service schedule for the actual centre gear set though. ie no replacing of the oil, which they say “isn’t available” (M-B 235.63). VW/Audi has. 🤷♂️
No, I don't know. If I were to guess, Graz. But that's a guess. Low-Res drawings of the rear drives of the G8R and A45s show the mounts and casings look different. So maybe just similar internals? After all, there only a limited number of ways you can get a twin clutch and hypoid gear set to look@veeeight, are you able to identify which of the Magna Europe plants builds the rear axle assembly in the VAG product?
M-B do not have a schedule or procedure for changing the centre hypoid gear set oil. "Lubed for Life"........ and do not list any products for 235.63 oil. I dare say that regular changes of a good quality 75W80 Hypoid oil will be suitable, if you are so inclinedand WIS lists no procedure for changing the rear axle oil – not for the center section
The A45S rear axle assembly definitely comes from Graz, out of what used to be the Steyr plant, before the takeover.No, I don't know. If I were to guess, Graz. But that's a guess. Low-Res drawings of the rear drives of the G8R and A45s show the mounts and casings look different. So maybe just similar internals? After all, there only a limited number of ways you can get a twin clutch and hypoid gear set to look
Well, that would be more useful than OEM Marketing Dept service schedules and processes!!Guys you’re going to start giving the molecular structure of each oil type next 😂
Which is all the more reason for sticking with AMG's P/N 's for lubricants.They behave differently for sure. Our cars are a lot more rear-biased, to the point of becoming scary on worn tires (Race mode, ESP-sport). But it's so satisfying to be able to break traction so easily, exiting roundabouts and u-turns being my favorite spots and you don't need drift mode either, Race mode will do. Needless to say people are often impressed seeing a hatchback do that. And we get that with only a 50% to the rear, that's even more impressive.
