What model rear diff oil needs to be replaced ?75W-85?75W-90or75W-140?
I can tell you one thing. I never, ever ran into a single problem in my VW, everything was in stock, down to the tiniest consumable, at every dealership or the aftermarket. I knew every little thing going into the engine and everywhere else and this paranoia that I'm going through right now, dealership ordering by my VIN and yet selling me the incorrect oil, was just never a thing. Or waiting for four fucking plugs like it's some kind of rare sh1t developed in some secret government facility 500 feet underground. Had tons of options.It's not ideal the situation we collectively find ourselves in around this lubricant situation. I'm guessing from @fatty45, response to my diff oil MB used, it is not necessarily exactly correct but it's not possible to tell for sure but it's generically possible it is correct.
I would be interested in @Turbo Ed experience on this in Australia. Or have I missed it in the size of the post![]()
I have given up trying to second guess why dealers give out the parts/lubes they do! No idea why they thought 235.15 was correct for your car. Unless they have an instruction that says substitution is OK…….@veeeight so the 235.15 that they gave me is for the single clutch differential systems, not suitable for our twin unit.
Many thanks for your help. I have sent MB an inquiry, waiting for their response. You know, dealing with extremely difficult situations such as this, changing oils in your car, you have to double check and then triple check.I have given up trying to second guess why dealers give out the parts/lubes they do! No idea why they thought 235.15 was correct for your car. Unless they have an instruction that says substitution is OK…….
@Forrester et alIt's not ideal the situation we collectively find ourselves in around this lubricant situation. I'm guessing from @fatty45, response to my diff oil MB used, it is not necessarily exactly correct but it's not possible to tell for sure but it's generically possible it is correct.
They probably weren’t expecting such micro AI analysis 😎No no no! Stop! No more muddying!!!!
M-B Germany does not think 235.15 is the correct oil for A45s!!!!
The following Mercedes website is what M-B Germany thinks should go into the rear diff twin clutch coupling…..
See
Mercedes-Benz Operating Fluids
Publication platform for approved operating fluids from Mercedes-Benzoperatingfluids.mercedes-benz.com
@Theo you can show that website ^ to your dealer.
Scroll down till you find:
“Axle gear oils, sheet 235.64 for TWIN rear axle differential rear axle for coupling, model 177 and 118 with engine 139”
235.64
235.64
235.64
235.64
235.64
235.64
And as the Dragon’s say… “I’m out” 😂 😂
*In true Mercedes style, that sheet has an error as it talks about a 9-F DCT for the W177 modelUnless @steve_3939 - has the A45s FL got a 9 speed gearbox?
Correct lubricant specification for a given application is not "micro analysis" it is prudent behavior.They probably weren’t expecting such micro AI analysis 😎
No aftermarket version of 235.64 in this country, to the best of my knowledge, which is precisely why my independent keeps buying it from the local MB Dealership.@Turbo Ed If I can't find the OEM 235.64, are there any aftermarket alternatives that you recommend? Don't mind the cost, what is the best 235.64 in your opinion?
Are we going to see a post anytime soon that you’ve tuned your car 🤔Correct lubricant specification for a given application is not "micro analysis" it is prudent behavior.
Knowing only too well the cost of our gearbox, I hate to think of the cost of our rear axle assembly!!!
NOW gone!!![]()
Turbine housing and exhaust manifold currently in LA, should be back early June at the latest.Are we going to see a post anytime soon that you’ve tuned your car 🤔
Completely off topic, as was your query.Turbine housing and exhaust manifold currently in LA, should be back early June at the latest.
Rods are due from Arrow around mid-June.
Head should be finished around the same time.
Then up to my Engine Builder.
If it is on the Dyno for Tuning sometime in August, I shall consider that the best possible outcome.
Won't surprise me if it turns out to be October.
Mine was related to your keeping everything about the car in such excellent condition when will we see the end result. I might even be in LA if your engine is late 😁Completely off topic, as was your query.
What to do when your "Daily" project turns out to be a total pain in the ***s?
Purchase a final year build Abarth 695, for which one can purchase, off the shelf hardware to achieve my 6 Lb /HP. (IE 400HP)
I don't know myself.
Like a kid in a toy shop!!![]()
You mean cruise to LA.I might even be in LA if your engine is late 😁
So if I can't find any aftermarket versions, and dealership can't get me the 235.64, I'll dump in the 235.15 which they claim is the correct oil and enjoy my rear differential for as long as it lasts. What else can I use, I can't pee in there can I?No aftermarket version of 235.64 in this country, to the best of my knowledge, which is precisely why my independent keeps buying it from the local MB Dealership.
In all my vehicles, this would be the first time I have had to do this in at least 40 years.
I am in the UK from early September until mid-October, which may also impact upon when the A45s is actually on the Dyno.Mine was related to your keeping everything about the car in such excellent condition when will we see the end result. I might even be in LA if your engine is late 😁
MB sent you the oil so you can always litigate against them if anything goes wrong. But I doubt it will. Same as mine, which may well have had the same substitute.So if I can't find any aftermarket versions, and dealership can't get me the 235.64, I'll dump in the 235.15 which they claim is the correct oil and enjoy my rear differential for as long as it lasts. What else can I use, I can't pee in there can I?
I hope you're right. And here's what I'm thinking...MB sent you the oil so you can always litigate against them if anything goes wrong. But I doubt it will. Same as mine, which may well have had the same substitute.
Note your concern in an email before they use the oil.I hope you're right. And here's what I'm thinking...
