61 - 80 of 83 Posts
In my case, spent about 6 months after purchasing my car for internet not to work.
If you load the general DTS project for the Hermes module, you can set it back to registration mode, or using the developer key version of Xentry - there's a special menu of 'Author Data' which contains the operational modes - set this to provisioning and reset initial VPN certificate beforehand; eventually will reconnect to Daimlers backend and refresh the certificate required to connect.
I found my car in crash mode, due to previous front-end damage. If the operational mode in actual values is in crash mode - likely this. Else, could be something else with Vodafone's backend etc, so contact the ITC team with the IMSI and they will confirm.
This is if you don't want to spend a hundred or more at MB. If in warranty obvs take it in...
Hi. Can anyone help please?
I live in Spain but have a German imported A35 (w177)
I have no data connection at all. I have contacted local dealership, Vodafone and Mercedes ME.
After 2 months of investigation and numerous trial and errors, Vodafone finally diagnosed the error to the APN set to Germany and needs to be changed to Spain (easy right?)
No!
I have contacted ME and dealership with findings and Delearship said its ME Connect that deals with it. I have contacted ME several times to explain the issue and kept having to be told I need to wait for update from their Tech Team to be told today that it cant be done...
Surely thats not correct!
They said the only way to get data on car is use wifi hotspot off phone. Ive already tried this and although the car says connected to mobile wifi hotspot, no data things work, I get No Internet error.
I have had an Mbux update 2 weeks ago to latest, so its not that. Ive also paid for full ME package
My ME Connect app connects to car, I can check status, lock doors etc but just cannot get any data at all, however, there is no toggle switch for 'Internet in the car' on my ME app?
Ive manually installed the latest Spain maps but on ME Connect app online , it still says the default region is Germany.
Without data I cannot use Internet radio, live traffic updates, live map updates and various other bits.
Does anybody know how to solve this as Mercedes seem to be clueless.
I hope this can be resolved.
Also, my Mbux doesn't have the Sync Profile option.
This also prevents some functions of my ME app from working.
Thank you in advance
Attached screenshot of ME & Vodafone emails.
No!
I can only suggest you read through this thread, plus these other threads, to see if any of the suggestions, or how it was solved for others, could help you.
Ultimately though, if your car is not in MB warranty, you may need to find a 3rd party coder that can recode the configuration in your car for you.
I have read everything, nothing helps my situation.
Nobody in Spain has a programmer to change to modem / sim settings. Not even Mercedes main dealer.
Plus I do not have the "Internet in the car" toggle switch on me app.
Also, on mbux I do not have the "Sync Profile" option.
I do have option to connect mbux to hotspot, but even when I do this, the car has no Internet.
Mercedes are a joke tbh. Nobody within Mercedes can resolve the issue...
It must be a single market requirement for MB to allow you to have the same operability for you, as long as it’s available, in your market. I would contact the MB CEO’s office in Germany and if no success look on the Commission website about who to contact about this.
Do you have an email address or contact info please?
I only have the UK ceo email. If you google it for MB ceo it should come up.
I give up with them mate. They are the worst support I have ever had. 2 months of being messed about, plus they charged me €260 for the mbux update (which didn't fix issue)..
I'll be selling car and getting something different.
Thank you anyway
No!
Just to add my comments, if the APN is set incorrectly - it can be adjusted for the HERMES module in DTS.
I'm not exactly sure if APN is the issue as there is the filtering content which is dictated by APN - I think? Do you even see the 4G/Me indicator on the main mbux system? If you do not me icon then your HU6 is not connected to the Hermes module, the Hermes module connects to the HU6 via a WLAN gateway.
There are many connectivity issues; if the app doesn't report remote states or any data information after the dealer verifies the logbook (e.g. my case) and adds your email to the VIN - then the issue lies with the Hermes module.
Saving codings of Hermes in DTS -> Xentry actual values, see operational mode.
Also check if the vehicle can ring me customer support using me button - if it does, good news - the Vodafone esim is somewhat working.
Now in my case, operational mode was set to crash mode, although, there are other states which can deactivate the data connection. In special versions of Xentry, there is a procedure to set this to the provisioning state. After doing so the HERMES module will re-establish a new VPN certificate for data connectivity to work with the car, the backend has a PKI infrastructure which uses a certificate-based authentication system.
Although, if the vehicle is in a provisioned state, then use DTS to set APN settings, I can't remember if this had per-country configurations but I don't recall there being many APN settings which I doubt is the case as the HERMES module should be able to do roaming.
Some other connectivity issues are that the MBux (HU6) unit loses time sync and the certificates no longer work - in this case, a special adaptation in Xentry resets the clock sync. Another adaptation is that the HU6 certificate becomes invalid and there's one to restore the initial authorisation certificate. The next time the car requests an updated certificate - it will be regenerated with the correct one for this vehicle. These are HU6 errors with connectivity and not HERMES ones though.
I had some experience with working on PKI backends at work last year and was lucky enough to delve into trial and error - a video from Duoyin with Google Translate helped me on this one :LOL:
Also, not all vehicles will have the Mercedes Me app on the MBux (HU6) - for example, I am on FUP4 and even with FUP3_4 there was no 'Mercedes Me and Apps' - it was always just 'Apps' on my system. Although, I paid for the personalisation option included in the remote package which allows you to have the 'Me' users within the system as this is not a free feature either. So I wouldn't determine the 'me' sync functionality to be a valid test routine.
Officially, I'm not sure if the Dealer has access to variant coding using DTS - but they can raise requests back to HQ for HERMES issues - therefore, I feel like some of the diagnostic work hasn't been done correctly. It does specifically state in one of the Xentry TIPS documents I located online when I had this issue - that this should be done if there continues to be no connectivity and some packet logs are captured as Xentry can communicate back to the backend with an official dealership account and will report back to the engineer if it can see any packets sent (similar to a wireshark).
Alternative methods used by people on Duoyin also attempted to export the variant coding of the HERMES module, then do a complete factory reset / reflash HERMES and reimport the codings. Which is basically an 'offline' SCN :ROFLMAO:
Thank you for that.
The ME button calls Germany, so it has connectivity. Vofafone diagnosed the issue.
Quote.
We have received the response from our Resolver team that you are using a HU CSP while trying to connect to a DE APN.
Please contact Mercedes help desk and let them setup the CSP correctly and make another attempt.
I have told both Mercedes Dealership and ME this, but neither has a clue how to correct it.
I too only have Apps (not Apps + ME). I dont have sync profile tab / button on mbux. I do have the option to connect phone via WiFi or Bluetooth hotspot, but even if these are connected, mbux has no Internet or data connection.
Cheers
Thank you for that.
Quote.
Cheers
Sounds like the dealer has upgraded your MBux to FUP4 - which gives the option for using hotspot, if there is no data using hotspot either - sounds like the MBux has a corrupted certificate and probably needs the initial authorisation certificate reset again.
Xentry -> HU6 -> Adaptations -> Teach-in -> Reset initial authorisation certificate
As for APN - yes you are correct; appears the HERMES module has a predefined list of APNs to choose from and what I said about the adult filtering switch is a UK-only thing.
I opened one of the database files in simulation mode:
There is an GUI which shows you the operating parameters, these are usually prefilled with a connected vehicle and will be green boxes; there are red boxes for anything wrong:
If the operating mode is under 'Crash Mode' you can use the button to reset it back to provisioning and it will reinsert the original authorisation certificate and the car will grab a working certificate off the MB server.
Officially, theres an option under Xentry with a long key enabling extra options to do this from there.
Anyone with a copy of DTS Monaco and the SMRD database from a dodgy source or the Xentry PKWs will be able to change this for you. You can use a cheap interface like OpenPort 2.0 which what I originally used or upgrade to a VCX SE if you plan to do flashing over DoIP which is overkill imo.
If you wish to go the official route - do complain to MB; I think the dealer hasn't followed the instructions of logging the connection (etc) to HQ which is part of the debugging process.
Another thing to ask the dealer is to request HQ to update the Vedoc codings to include the APN for DE and then when they perform SCN it will automatically change over to DE. As if you go this route; every time there's a new Hermes module update - it will regrab the old codings from the MB database and change the APN again back to HU if you use the variant coding change.
Hope you'll find a solution officially or the unofficial route; I seem to think dealers are clueless tbh as mine had no clue that there was even a 'crash' mode which prevents data but allows sms/calls.
Wow. Thats an amazing reply. I'll take that to my local auto electrician tomorrow and show him, see if he can do. Otherwise, I'll be going back to my dealership and show them your instructions. Thank you do much. This 2 month drama may get solved at last.
Hello everyone.
I have a concern with my Mercedes me after analysis with Xentry I noticed an error code on the WLAN of the MBUX.
I read a lot on the subject thank you to those who posted solutions but there are some differences with my problem.
Here is the error code and here is the menu I have in Xentry.
Does anyone know the procedure to solve this problem?
I can call the SOS and I Mercedes with the car but I cannot be updated.
And I have the SOS error message not activated when it really fills up.
Thank you.
MERCI.MERCI.
Hello everyone.
Thank you.
MERCI.MERCI.
What is your MBUX software version number?
Good morning Veeeight and thank you.
Unfortunately no I did not manage to adjust this failure.
I have an NTG6 I am not affected by this tips.
My two problems are DC27 code and WLAN NO connected to the NTG6.
The SOS button works the Mercedes buttons I work my GPS works but we can not commit with the car with the Mercdes application, the services can not be activated.
If someone has Indés or a procedure to try to reset the NTG6 and the Hermes I am interested.
Than you.
Hello cowen1000
Have you managed to solve the problem? I’m in a similar one myself. I own a Spanish A250e in Portugal, the car was imported and registered here. The comfort internet data package doesn’t work.
Vodafone states the car APN has to be switched to Portugal and Mercedes dealer can’t do it. The dealer even said they spoke with Mercedes HQ (maybe not true but they said it) and apparently Mercedes does not allow a car to be change the market (Spain to Portugal).
If you managed to solve the problem, can you please list the steps?
TIA
61 - 80 of 83 Posts
