I just wanted to buy a litre of top-up oil for my new A200 petrol engine. Would I be correct in thinking that any fully synthetic 0W-20 oil would be suitable.
You know 5W30 and 0W30 are same thickness right? (in HOT ºC). not in COLD.My A35 is on 13K miles and I've only used Castrol Edge 5W30 M for all services. This is a slightly thicker oil than 0W30 and I haven't had any engine issues, neither have I needed any top ups between services. I also own a gen 1 Porsche 997 and these cars have a widespread known fault with cylinder bore scoring. Hartech are one of the most respected engine specialists in the country, who have also designed and developed industry leading solutions to this issue. Porsche also specify a 0W30 oil for these cars, but Hartech who have rebuilt hundreds of these engines, recommend a thicker oil of at least 10W50 viscosity. Obviously our engines are different, but the principle of not using oil that's as thin as water is what should be of concern, when it's flowing through and coating engine parts.
Fuchs is excellent quality.Not sure if I would be buying Fuchs again - I can presume it is good oil but I'd prefer the more name brands.
Ah good to knowFuchs is excellent quality.
It’s a little rabbit hole I wouldn’t recommend exploring, but essentially the additive package that makes it compliant to API SN or SP is only made by around 5 companies - so no matter which “brand” you buy, they will all use the same additive package.
(And the Group IV PAO base stock is also made by a handful of companies worldwide, of which Fuchs is one of them …..)![]()
