MBUX 1 (NTG6) - Newest Map Updates Thread
5 reading
102K views 211 replies 43 participants last post by  veeeight
Got an e-mail from Mercedes yesterday that a new map update is out. Enjoy.
#11 ·
Just got this - I’ll check in the morning.
Part of our offer for you is the "Online Map Update" service.
We have new navigation maps waiting for you.
The map for your region will be automatically installed in your Mercedes at no extra charge.
Should you require new maps for other regions, please visit the Mercedes me Portal to download these free of charge.
Kind regards
Mercedes me
#15 ·
Hey peeps what's the new version number, just so I could check if the new map has downloaded and installed?
#22 ·
Mercedes say in the online instructions, that it can take several months as an OTA update, which is why I have always downloaded it manually; it only takes a few minutes.
They don't use peer-to-peer for their OTA updates, so there is potentially huge overheads on their servers in sending data to all MB cars on the road. I'm guessing this is why the map updates can take so long and why they don't even attempt to push out their non-essential cosmetic updates, which are probably large files because of the graphical content.
#26 ·
Mine is failing. First time got to 37%, and now it won't go past 2% before it pops up an error that it failed. I am doing it slightly differently so I don't know if that's the problem: I downloaded (only UK+) to a blank SD card, then copied the files over to my semi-filled thumb drive (with music and cameras). It recognises it fine, and like I said, starts the install, then ends.No idea why. I tried with a fresh download and a different socket (both under the armrest) but the same issue.
#33 ·
So, weird. Yesterday I did the following:
1) downloaded the update to an empty SD card in my PC (which is annoying because a) it won't let you download to the hard drive, and b) no reason why it makes you download to an empty drive, so I had to move all the stuff off of it temporarily)
2) I only have one USB thumb drive, which has all of my music, and the speed cameras, so I didn't want to empty it. Instead, I copied over the downloaded files from the SD card to the USB drive
3) The car recognised that the update files were available. First time it got to 37%, then after a long pause, popped up an error message that the update had failed. I tried again and it got to 1%, long pause, pop-up message, tried again, got to 2% then same thing, and two more times, same thing.
4) After doing absolutely nothing (the car was parked overnight), I tried again today, and it worked! It took a while, with a very long pause at 39%, but this time it continued on to completion.
#36 ·
Thanks @veeeight , I just found this out myself whilst sitting in Sainsbury's carpark. If you go to Settings Software update you can see how far the update has progressed. Mine was on 65% when I found this 🙄 then it suddenly jumped to Finished.
Just for interest I plugged in a second usb with the maps on and although the car still showed my music on my first usb the Personal POIs were missing until I pulled the second usb
