Has anyone added the projector LED'S into the W177 doors I have done it on my old W176 but the W177 looks different anyone have any ideas?
coding needs to be done on the OEM ones. Most garages just don’t realise it. That’s the whole point to this thread. I’ve already sent the official MB coding guide to 30+ forum member for them to prove to their garage that coding is needed.Just got off the phone with my merc dealer. £101.50 to have them direct from Mercedes, free labour costs as they only need to be popped in with no need for adapters apparently. Seems no coding needs to be done?
(I have a 19 reg premium amg line)
Got you, guess I'll wait for them to flicker and take it back in 😅coding needs to be done on the OEM ones. Most garages just don’t realise it. That’s the whole point to this thread. I’ve already sent the official MB coding guide to 30+ forum member for them to prove to their garage that coding is needed.
It might work for while without but will eventually flicker a little
I can just mail you the guide so you can show them where to search in their database. It’s literally a 2 minute coding. But since it’s plug and play in most other models they are not used to it. My garage wanted to replace all electronics in both doors and refused to acknowledge that coding was needed. Once I contacted MB directly in Germany forwarded their guide they went quiet and fixed it instantlyGot you, guess I'll wait for them to flicker and take it back in 😅
That would be good if possible! Saves the hassle later on! I'll pm my emailI can just mail you the guide so you can show them where to search in their database. It’s literally a 2 minute coding. But since it’s plug and play in most other models they are not used to it. My garage wanted to replace all electronics in both doors and refused to acknowledge that coding was needed. Once I contacted MB directly in Germany forwarded their guide they went quiet and fixed it instantly
Hi man,Absolutely love them!
Car Door Logo Lights, FlexDin CMS-BZ2 2PCS Custom LED Door Courtesy Puddle 3D Laser Logo Step Ghost Shadow Projector Lights Lamp for Benz A-Class/New C-Class, No-Drill https://www.amazon.co.uk/dp/B07DHN1JHR/ref=cm_sw_r_cp_apa_i_brN5CbRYWQ2BM
Does this mean that 4x doors need to buy 4x adapters?There is now an official Mercedes adaptor available to prevent the flickering, instead of needing coding changes. View attachment 8359
This is good, as mine are coded in and they still flicker from time to time, mostly when the engine is running / just been turned off.There is now an official Mercedes adaptor available to prevent the flickering, instead of needing coding changes. View attachment 8359
Are the adapters and lights from Merc?I got these fitted today, easy enough to do just clips in, Like I say I did have them coded in but they still seemed to flicker everyso often
Can you provide a link for these?I bought these from China for around USD 25 with shipping.
It also has heat sinks built in and the image is considered fairly sharp. No coding required.
Been using them since January and no problems so far.
You can check out the video via this YouTube link, can't seem to share the video file here.
Any chance for pictures of what the door lights look like in action?
Here you go, go for S2.Can you provide a link for these?
View attachment 9751Anyone with a W177 with door LEDS if so can you provide pics and links please thanks.
yes i have this problem, what was the solution?Nice @AziiikovMy MB ones are playing up and have been replaced once already. They flicker on and off or don't come on at all intermittently.
i also noticed it only happens when the engine is running- they flickerNice @Aziiikov
